setting material property
peter__smith
peter__smith
I have 2 panels. I want to set the meterialproperty as follow:
panel 1 (see pict 1): green flat appearance in 3d-model, and gray flat appearance in 2d revit-sheet
panel 2 (see pict 2): green flat appearance in 3d-model, and crosshatch (black-white) in 2d revit-sheet
Question:
Something is wrong with the setting of the both panels. Does anyone know how I can fix to the wished materialproperty?
Kind regards,
peter smith
RDAOU
@peter__smith
Same applies to both Panels
To show the green color:
  1. Visual style in both Views should be Shaded
  2. Remove the Background solid surface pattern
  3. Make sure the "Use Render Appearance" is unchecked
To show second view (the section) to show gray while the first remain green:
  • Either set a Cut solid pattern and make sure the section cuts the element
  • OR if the section is actually an elevation too, the you need to override by element or category
peter__smith
The result of the last one exactly what I want.
Is it possible to arrange this overrule setting in the material property, because there are a lot different paneltypes in a project?
RDAOU
@peter__smith
You can set up the Override By Category (of by filter) and add/use that in a view template
Example:
  1. in one section >> Override By Category instead of element
  2. then Go to View Tab >> View Templates  >>> Create template from view
  3. Then in the Project Browser select all the sections or elevations and on the Properties Pallet apply the template
When you apply it to the Section views they will all be overridden (See GIF below)
peter__smith
Thx for the explanation. I already used viewtemplate for the elevation drawing.
If the appearance panel in the 2d sheet has to be adjusted to another colour, than I have to use "filter" function.
Isn't it?
Kind regards,
peter smith
RDAOU
@peter__smith
You override elements on views and place views on sheets...meaning whatever override by filter or by any means is applied to the view
