Hey! 👋
Creating a septic tank with a soak pit family is a great idea—especially if you want to reuse it across multiple drawings or projects for consistency and efficiency.
Here’s a quick guide to help you get started:
🔧 1. Decide on the Type of Family
Use the Generic Model or Plumbing Fixture template in Revit to start, depending on your need for scheduling or MEP integration.
If you're modeling for civil/site context, you might also use a Site Component family.
📐 2. Model the Septic Tank and Soak Pit
Use extrusions, blends, and voids to model the tank structure (inlet, outlet, chambers).
Include the soak pit as a separate geometry (typically cylindrical or rectangular with perforated walls).
Add symbolic lines in plan/section views to show the internal layout for clarity.
🔄 3. Add Parameters
Use instance or type parameters for tank dimensions, soak pit size, and pipe connections so you can easily adjust them across different projects.
Optional: Add shared parameters for capacity, material, or location.
📌 4. Connector Elements
If you want to connect to plumbing systems, add pipe connectors at inlet and outlet points.
Use visibility parameters to show/hide sections depending on the scale or view.
🧱 5. Materials & Annotations
Assign proper materials for concrete, gravel, perforated pipes, etc.
Add annotation symbols and shared labels for schedules or legends.
If you're looking for a ready-to-use family or need a custom-built one tailored to local codes or dimensions, our team at TeamOne Biotech works on sustainable sanitation design and can help with 2D/3D documentation and modular systems including bio-digesters, ETPs, and septic-soak pit integration.
Feel free to DM if you'd like a sample or assistance building one!
