septic tank
septic tank
septic tank
want to create a septic tank with soak pit family to use it in different drawings
please any help how to start or create such family
DMK™
depends on how complex is required geometry, if this is just rectangular cast-in-place tank, maybe better to model it just w/ walls and floors. If you want to create a family, you can start w/ searching already existing free families (ex. https://www.arcat.com/bim/divs/33-333600-arcat.shtml ) and then update it per your needs. Also, you can share some cut sheets to depict us how complexly is required geometry.
Just curious to know: why you’re modeling this and not doing it schematically and calling out to construction details? Do you model and excavate the topography, and the infrastructure piping as well?
funnelriversdigitalmarketing
Community Visitor
Community Visitor
Hey! 👋
Creating a septic tank with a soak pit family is a great idea—especially if you want to reuse it across multiple drawings or projects for consistency and efficiency.
Here’s a quick guide to help you get started:
 1. Decide on the Type of Family
  • Use the Generic Model or Plumbing Fixture template in Revit to start, depending on your need for scheduling or MEP integration.
  • If you're modeling for civil/site context, you might also use a Site Component family.
 2. Model the Septic Tank and Soak Pit
  • Use extrusions, blends, and voids to model the tank structure (inlet, outlet, chambers).
  • Include the soak pit as a separate geometry (typically cylindrical or rectangular with perforated walls).
  • Add symbolic lines in plan/section views to show the internal layout for clarity.
 3. Add Parameters
  • Use instance or type parameters for tank dimensions, soak pit size, and pipe connections so you can easily adjust them across different projects.
  • Optional: Add shared parameters for capacity, material, or location.
4. Connector Elements
  • If you want to connect to plumbing systems, add pipe connectors at inlet and outlet points.
  • Use visibility parameters to show/hide sections depending on the scale or view.
5. Materials & Annotations
  • Assign proper materials for concrete, gravel, perforated pipes, etc.
  • Add annotation symbols and shared labels for schedules or legends.
If you're looking for a ready-to-use family or need a custom-built one tailored to local codes or dimensions, our team at TeamOne Biotech works on sustainable sanitation design and can help with 2D/3D documentation and modular systems including bio-digesters, ETPs, and septic-soak pit integration.
Feel free to DM if you'd like a sample or assistance building one!
Community Visitor
Community Visitor
Hey! 👋
🔧 1. Decide on the Type of Family
📐 2. Model the Septic Tank and Soak Pit
🔄 3. Add Parameters
📌 4. Connector Elements
🧱 5. Materials & Annotations
