September | New Knowledge Network Articles
matthew.d
Alumni Alumni
matthew.d
Question: Where can I find a list of the Autodesk Knowledge Network support solutions that were created and/or updated in the month of September?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
matthew.d
Week 1:
Collaboration for Revit: How to use and access subfolders on A360 Team
Error: “Revit cannot find default servers for the external services” on launch
Linking issues when importing AutoCAD and Revit data into 3ds Max 2016
Revit Cloud Rendering: Comma prevents view from being rendered
Revit: Flipped display of wall layers in section view depending on the “Head Height” settings
Revit:Family parameters may appear under a different group in the project environment than it is set...
Week 2:
Can’t import Landxml file with Autodesk Site Designer Extension for Revit 2016
Collaboration for Revit: Unrecoverable error when closing Revit
Foundation families in Revit show faulty dimension paremeter values
Manage DWF output from Revit MEP
Revit: Split Face transparency makes entire object transparent
Week 3:
Cast in Place Monolitic stair with chevron shape
Elevation is incorrect when creating street by using ?Constant Elevation? in site designer addin
Revit: Accept primary option unexpectedly deletes views
Revit: Direction of room calculation point is not consequent at the different language libraries
Revit: Linked room will not tag
Revit: Partial Border Tile option 2? past border
Week 4:
Area of door is incorrect after exporting model to IFC from Revit
Collaboration for Revit: Publish fails
Error: “The request could not be satisfied” when clicking Sub Center options
New browsers not supporting Silverlight for Revit Server Administrator
Pressure Drop value doesn’t seem to work on dampers in Revit 2015/ 2016
Revit: Feature Request - Adding Parameters to Materials
Matt DiMichele
