Self intersecting splines are not allowed in sketches.
Ajay_J_S
Ajay_J_S
hi i got this error when drawn this sketch using spline Self intersecting splines are not allowed in sketches.
constantin.stroescu
You are not allow to have:
  • self intersecting lines - that includes overlapping lines
  • lines shorter then 0.8 mm
  • open polylines if you intend to create Forms (extrusion)
Constantin Stroescu
Mike.FORM
Tip of the bottom right leaf extension doesn't look like it is properly connected, but you probably need to check all your vertices.
As @constantin.stroescu said you just need to make sure not to break any of those rules.
Draw a half and mirror it.
