Can I adjust wall face pattern individually without constraints to the other wall face?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
julia_cheong
449 Aufrufe, 6 Antworten
Hello, hope you all are doing great.
I'm working on the Exterior Wall of the building in Revit, and struggling with pattern of the wall.
If I align a vertical line of the face A, the pattern of the face B also moves with it.
Is there any way I can adjust it separately?
Thank you.
6 ANTWORTEN 6
Nachricht 2 von 7
jvpantin2
als Antwort auf: julia_cheong
First of all, verify that wall pattern is a model instead of a drafting type, otherwise you won't align it.
Then, try with these two options:
-Unjoin (separate) walls and align patterns one by one,
-If that doesn't work, create parts for both sides of wall and then align them separatelly
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
Nachricht 3 von 7
kostask_oionei
Is this one wall with wrapping at ends or at inserts?
In this case I don't have problem to adjust the pattern separately.
Tab + click to select a vertical or horizontal line of the pattern and move it.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Nachricht 4 von 7
Paint the face you want to control independently with the same material prior to aligning the pattern.
Nachricht 5 von 7
julia_cheong
als Antwort auf: kostask_oionei
Thank you for your reply.
I have treid the same way, but It didn't work.
I have created the same walls on different levels, but some of them work well&some of them doesn't.
Nachricht 6 von 7
julia_cheong
Thank you for you reply.
I have tried to align them, but some of them work well, and some of them doesn't.
Nachricht 7 von 7
julia_cheong
als Antwort auf: ToanDN
Thank you for your solution.
It it working and I believe that this is the best way.
Thank you so much!
