Selection Window (click and drag to select multiple inside of or crossing)
bchaney0927
bchaney0927
Revit LT 2017
When I try to select multiple items by click and drag rectangle, an example being some furniture on a floor, the floor is selected and moved instead of being able to make the selection rectangle for the furniture.
The only workaround that I have found so far is to pin the floor and then set the toggle for whether or not a pinned object can be selected.
I'll keep sifting through options and will post any other solution that I can find, but any help with this would, of course, be appreciated.
Thanks!
Bennett
Make sure Click and Drag is turned off.
mpeperkamp
Hi @bchaney0927,
When you make a selection you can use the Filter.
So you can deselect the categories you don't want to select.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
