Selection into view filter
jfjacques
Message 1 of 8
jfjacques
I have made a selection set.
I have isolated this selection in my view.
I have placed this selection set in vg filters and checked it.
At the moment if I add new items to the model in other views, they show in the Isolated selection view.
Say this selection set is for windows. I want those windows to be the only thing showing no matter what I may add to the file in other views. How do I manage this?
Replies (7)
Message 2 of 8
If you are adding elements to project that are to be controlled by a Selection Filter, you need to add each one of them to the Selection Filter manually. It isn't automatic. Rule-Based Filters are.
Message 3 of 8
Are you doing a window legend?
Message 4 of 8
jfjacques
yes,
but this is crazy, I can't set a filter that omits new objects unless it's rule based...
Message 5 of 8
@jfjacques wrote:
yes,
That is normal.  Rule based filters work because you can set the rules to Not Equal To.  Selection filters do not have that capability.  Make a rule based filter to isolate something(s) is simple and should even be easier than making a selection filter.
Message 6 of 8
FAIR59
What you are wishing, sounds like the properties of an assembly. In assembly views, the only elements visible are the elements of that assembly !
Message 7 of 8
Corsten.Au
Hi
Try to use some parameter to filter elements out..
Heres an example for.
Wall - Comments - show
Windows - Comments - show
Filter - Elements without Comments show - and hide .
Corsten
Building Designer
Message 8 of 8
That was the reason I asked if he is doing window legend.  I had suggested Assembly and Assembly views for Curtain wall legend in the past but he wasn't too fond of it 😉
