Select previous doesn't select previous but before (R21)
Hello everybody,
Something strange happens when I want to do something with the last used object again.
For example; I have got 2 families, first I move family A and after that I move family B. After I deselect family B and I want to move it again, I need to select him manually first. If I use the "select previous" function, Revit selects family A...
Does this sound familiar to anyone and does anyone know how to adjust this so that Revit selects family B instead of family A?
(I am using Revit 2021.1.2)
RDAOU
@Anonymous
Do not hit escape after the move command or any command (that is an Autocad habit)... The behavior in Revit is as follows:
  • If you move A >>> then move B >>> then left click in a blank Area (Select Previous will pick B)
  • If you move A >>> then Move B >>> then hit Escape after the move command (Select Previous will pick A)
  • If you move A >>> hit Escape >>> Move B >>> Hit escape >>> Select Previous will be either Greyed out or will pick the last element you modified/moved without hitting escape after the modification
Edit: See illustration below
