Select all instances is not available
Message 1 of 12
Hello everyone,
I am editing the walls in the show parts mode and I cannot select the similar objects. Is there any way to resolve this issue?
Elio
Replies (11)
Message 2 of 12
martijn_pater
Parts are parts, not similar objects. If you set parts visibility for the view under graphics to show original, you can select the similar wall types.
Message 3 of 12
Thank you, Sir
I am aware that if I apply the command 'Show original' I can select similar objects, but that's not what I need...So there is no way to select the similar parts in Revit in 'show parts' mode?
Message 4 of 12
martijn_pater
I think no parts are identical. What you can do is use select similar on the originals and save that to a selection set, then in parts load this selection set, isolate elements and select what you need from the parts (possibly save another selection set for those).
edit: Actually you can also just apply temporary view properties and turn off all model categories except for parts. Then create a selection set possibly. Easier method.
Message 5 of 12
RDAOU
@Anonymous
If you are trying to create Part Sets... You can do the following:
  1. Create a filters for Parts (per layer /rule by material)
  2. Filter view for 1 material
  3. Select all and create X Selection set depending of how many layers/material you have
Message 6 of 12
Thank you Sir,
This procedure simplifies my work.
Best regards
Elio
Message 7 of 12
RDAOU
@Anonymous  you're welcome
Message 8 of 12
martijn_pater
So you don't have parts with the same material? How many instances are we talking about?
Message 9 of 12
RDAOU
Then you filter the parts with any common parameter to create sets 🙂
Message 10 of 12
martijn_pater
I realize how to do it, but if you have just 10 ie. you can just select them instead of going through the trouble of creating filters especially for that but this is not specified in the question...
Message 11 of 12
RDAOU
When one is working with parts and shop drawings from parts, one has to create those filters anyways...even with 2 walls
Message 12 of 12
martijn_pater
Well ok then, didn't realize that. Will keep it in mind.
