Message 1 of 16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This is how you can segment a section. but it seems you only can adjust from where you see the section. So it adjsut what you include from where we see.
But what I want to do is adjust how far I can see. See below. The red should be how far I can see and the blue part should NOT be seen. in my example the blue area is a separate room and the section also shows things in that room, which it shouldn't. I tried to use an elevation, but that shows me the same.
Is there a way to do that? Google told me thee is a plugin, but i cannot install plugins (IT rule). So i need to do it with what Revit gives me.
I want to avoid having to place 2 sections next to each other.
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
