sections
sections
in the section I see the brick patterns despite taht the view setting is set to coarse. I don't want to see the brick pattern at all. many thanks
josemukalel
Remove Surface Patten form your wall type
Jose George
Architectural BIM/CAD Technician
josemukalel@gmail.com
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
josemukalel
IF you need to remove from only this view,go to VG-WALL-SURFACE PATTEN-UNCHECK PATTEN OVERRIDES
Jose George
+64 22513 0828
rodrigo.bezerra
The material's surface pattern is always visible, disregarded the view
detail setting. I'll need to override it in the view, like said above.
Do not forget to mark as solution the replies that answers your doubts. It
helps other users with similar doubts.
Best regards
Rodrigo Bezerra
How on earth can I accpet an answer as the solution when I dont see a option or a button for this in my web browser. I keep on getting meilas and complains about this whereas nobody has given me the benefit of teh doubt taht maybe there is a technical issue which disables me to click the option which is accpet as solution.
