& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
in the section I see the brick patterns despite taht the view setting is set to coarse. I don't want to see the brick pattern at all. many thanks
Remove Surface Patten form your wall type
IF you need to remove from only this view,go to VG-WALL-SURFACE PATTEN-UNCHECK PATTEN OVERRIDES
Rodrigo Bezerra
How on earth can I accpet an answer as the solution when I dont see a option or a button for this in my web browser. I keep on getting meilas and complains about this whereas nobody has given me the benefit of teh doubt taht maybe there is a technical issue which disables me to click the option which is accpet as solution.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
