Section: line gap
Section: line gap
XXalessio.amodioXX
Section: line gap
XXalessio.amodioXX
hi all ,
Can I create a section like in pic?
loboarch
Yes no problem.
http://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-B2C74B6B-C1CF-4667-85E8-F155BA8601AB
Jeff Hanson
Principal Content Experience Designer
Revit Help |
aRcHiTeCt.JM
... hi @XXalessio.amodioXX
... click on the section line
... and then click on split segment
... and drag the line from wherever you want it to break
... as many times you want in the same section
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
kadmonkee
yes
you create a new section line
select the line and use the split segment tool
pick on the line and slide the curser up or down in the direction you want.
you can do this multiple times on the same section line
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
