Section Head won't flip as section does
Hello! I'm trying to make a sectionhead that looks like this. In default it's great, but as soon as I flip it or try to make it vertical the Label that I've put in wont follow like the arrow does.
I have tried following:
-Placing additional labels with visibility parameters. Won't work as the sectionheads instance parameters aren't availible in the section properties.
-Drawing invisible lines in the editor and grouping it with the label thus making it alignable and lockable with the arrow. Won't work, no idea why. The "cross" of lines which I've grouped the label with works as it should, however the label is stuck in it's usual place.
I'm out of ideas. Anyone who has encountered this before and solved it?
hi, i had the same problem, the label doesn't follow
so i fix it with two type of section head, one for horizontal and one for vertical.
and it is practical cause after i can sort the section
Yeah, maybe that's the way to go. Thx!
