Section Family Double Click
sflachDPXRV
Message 1 of 10
sflachDPXRV
Generally when you double click the section line in a view that will take you directly to that section view. In some of our projects that function is not working, when the section is double clicked nothing happens. I went to check the template file and the sections work as they should and open the view when double clicked. Are there possible project settings that would disable the section? Or is there a way to fix this family in the project?
Replies (9)
Message 2 of 10
Alfredo_Medina
No, double clicking on the section line does not go to the view. Double clicking on the pointer or arrow of the section tag does go to the view.
Message 3 of 10
Either double click the Section Head or right click the section line and choose Go To View.
Message 4 of 10
sflachDPXRV
This is what I am referring to, in some projects double clicking the section arrow doesn't  take you directly to the view.
Message 5 of 10
RDAOU
@sflachDPXRV
Last time I have seen that behavior was in Revit 2018.
  1. Is that happening on a specific model in a specific version? or all models?
  2. Do you have too many Linked/Imported CAD files?
  3. Did you try to use a different section head?
Message 6 of 10
Are you clicking on a Section View that is Referencing another View?
Message 7 of 10
RobDraw
Share a model that exhibits the behavior.
Rob
Message 8 of 10
MichaelGröger1110
I have the same problem.
Double Click only works on one end of the section lines arrows.
E.g. a click on the arrow on top will work - but the 2nd arrow (on same line) does not.
Bug or Feature?
I figure the double click only works if section line is not selected.
Press ESC a couple times bevore you click.
Message 9 of 10
Shabbiraliamz
Community Visitor
Community Visitor
exactly click on this line will help
Message 10 of 10
Ahmed.Elmahdy
Hello All,
 I had similar issue with outside coming project, I noticed when I click the tail I can Enter the section so I  figured out for unknown reason the families used in section tag parameters were switched as attached screenshot, I just corrected it and worked fine.
