Wall
Wall
sabamail65
Wall
sabamail65
Hello.I have a plan in the form of a submitted photo. But I do not know how to show the walls as shown in the photo. Without creating walls of different thicknesses.
hmunsell
Yep, that is pretty much how you would do it.... make different wall types of the different thicknesses. I count maybe 5 different wall types? it looks like several of those would be Columns. if the column is the same material as the wall it will merge with the wall.
Howard Munsell
sabamail65
Thank you
RDAOU
@sabamail65
Why don't you want to use several types? any specific reason?
You do not need to worry about the layers..you can simply duplicate a Generic Wall and just change thickness...you would need some 10 duplicates ... see colors below + the Circled in red would be columns
syman2000
Just use Architectural column for all the bump out. When you draw the wall and place architectural column it will merge and the column will inherit the wall material.
Create an architectural column family with instance width and length parameters so that you can stretch it to fit in project.
sabamail65
Thank you RDAOU
