SECTION BOX NOT WORKING
loebjl
Observer Observer
loebjl
Observer
Observer
I am an architecture student and I am currently touching up an old project that I made using Revit 2022. The section box on this file used to work, however whenever I open it to do work for the past 6 months the section box doesn't work. I will attach images below. In the first image, this is how it looks when my section box is turned ON, and in the second image this is how it looks when it is turned off. I am not sure why it is doing this. If anyone has any suggestions on ways to try to fix it, it would be greatly appreciated.Screenshot (1723).pngScreenshot (1724).png
VG, Annotation tab, turn on Section Box category so that you can see it
loebjl
Observer
Observer
I went to check and its showing its already turned on
Is section box set to white color under object styles?  What about deleting that 3d view and recreate a new one?
syman2000
If you check on the reveal hidden element, did the section box show up?
loebjl
Observer
Observer
It worked thank you so much!!!
