Revit 2021: Stair Railing
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
jchoneycutt
255 Aufrufe, 2 Antworten
I'm working on stairs right now that have 2 landings on top of each other in one level. This mainly happened because the distance between levels is too high and I had limited area for the stairs in plan.
Whenever I place the railings on the upper stringer, it keeps getting hosted on the lower stringer. I've included a screencap of what keeps happening below. How do I solve this? Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: jchoneycutt
Use Railing dropdown and choose Sketch Path, not Place on Stair/Ramp, then Pick New Host from Ribbon and TAB to select the correct Run.
Nachricht 3 von 3
jchoneycutt
thank you so much!
