Searching for BIM360 projects from Revit Home Page
diego.gonzalez_sanz
diego.gonzalez_sanz
When accessing BIM360 projects from Revit's Home Page (Via the Desktop Connector), it does not seem to be possible searching projects by their names (This function is possible in the BIM360 via website)
I work with many BIM360 projects and have to go trough the whole list to find a specific project. As the list of projects increases this will be an even harder and more time-consuming task.
As a complementary obstacle searching for projects on this menu, the bar where the projects are shown is fixed and cannot see the whole name of the projects.
Is there a solution for these issues?
Nota: I am using Revit 2019.2 version.
Best regards,
Lance.Coffey
Autodesk Support
Autodesk Support
Thank you for the feedback @diego.gonzalez_sanz and welcome to the Autodesk forum!
I found an idea thread on this topic here: Improve BIM project browser and search
If you would like to see this idea implemented, please vote it up.
Regarding the width of the display, there have been changes in later versions so that the list of projects is no longer on the left side, but in a separate pop-out window (to see this, take a look at the 2022 version).
Lance Coffey
Technical Support Specialist
