Screen view moves automatically when I change something?
Message 1 of 15
An annoying change happened to Revit in the last update.
Now whenever I make any change to a view on a screen, Revit automatically shifts my view.
This is downright annoying as most often I have my eye on a 3D object in the view and need to see how the change impacts it and when the view shifts I lose sight of it.
Is there some new on/off option for this stupid feature?
Thanks in advance.
Replies (14)
Message 2 of 15
RobDraw
Now, what makes you think that is by design? This is the first I've heard of it. If it were a "feature", we would be hearing a lot more about it than this single thread.
What have you done to try to fix this?
Rob
Message 3 of 15
Viveka_CD
Hi @Anonymous
It's been a while and I'm checking back on this issue. If you continue to face these issues, please let me know.
  • Which version of Revit are you using?
  • Do you have a multiple monitor setup?
Looking forward to your reply update.
Message 4 of 15
Hi Viveka,
I sent you some logs with this same issue many months ago and never got an answer.
Our screens are still jumping around like Kangooroos.
Using Revit 2018.2 and three screens.
Message 5 of 15
@RobDrawThis is not a new problem
http://bim4scottc.blogspot.ca/2012/06/jumping-revit-view-aka-revit-jitterbug.html
https://forums.autodesk.com/t5/revit-mep-forum/jumping-3d-views/m-p/2300243/highlight/true#M4857
I don't think anyone ever found a solution and Autodesk has not released anything acknowledging the problem or offering a fix. This is not something a user can "fix" as far as I know, it's a core Revit graphic bug.
Message 6 of 15
RobDraw
Okay, that makes two.
Rob
Message 7 of 15
This issue predates 2012, so that makes for a lot of people whose issue has been ignored. Wayyy more than two Smiley Sad
Message 8 of 15
Have you seen this post below from the very link?  Sadly I have never had the problem so I don't know how to help you.
Message 9 of 15
RobDraw
Okay, three. I'm really not sure how that relates to this thread as the OP only started experiencing it after the latest update as of the date of his post.
Rob
Message 10 of 15
Viveka_CD
Hi @Anonymous
Let me check back on this with the dedicated resource.
Please share the other thread's link here as well. It makes easier to combine and move things up.This way I can prioritize.
Yes. this issue is common with multiple monitor setup and changes to display configurations.
I will share updates as soon as I hear from development.
I will get back if we need additional files from your end.
Message 11 of 15
Viveka_CD
Message 12 of 15
I tried deleting my main view without success.
Message 13 of 15
Viveka_CD
Message 14 of 15
Yes, been having this problem for the last 6 years, so it was present on Windows 7 and 8.
Message 15 of 15
Viveka_CD
@Anonymous
One thing that was suggested by the team handling similar issues was to
Let me know if this helps.
