Scheduling
Scheduling
Scheduling
I'm trying to schedule some Appliances, I don't know why some of the dimensions won't show in schedule. Seen below. you can see for example, the second row, the Depth even though it is in the family, it won't show in schedule.
Thanks!
Does it have a Depth Parameter? In-Built or Shared Parameter?  If Shared, check your available Parameter fields; you may have more than one "Depth" listed.  Happens if the families were created using different Shared Parameter Files.  Shared Parameters are identified by GUID; not by name.  So, it is possible that more than one "Depth" exists in Project.
The Depth parameter needs to be a Shared parameter. On top of that, it needs to be the same shared parameter across all the families you want to schedule.
