Scheduling Metal Studs
Message 1 of 22
I'm trying to schedule some partitions, and I was wondering how best to schedule the Metal Studs, in linear foot. I have the area in sqft and maybe with formulas can generate it in linear feet, but wanted to ask if I can somehow maybe through Curtain Wall or somehow. Any suggestions.
Thanks!
edit: can I through modelling achieve to schedule metal studs
Accepted solutions (3)
Replies (21)
Message 2 of 22
cbcarch
check here:
https://www.clarkdietrich.com/support-tools/bim-systems
http://www.aga-cad.com/products/bim-solutions/metal-framing-wall
https://www.youtube.com/watch?v=A-OMgXU6e6g
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 22
Should be easy to accomplish. Would need more information about your workflow though.
Are the Metal Studs actual individual components in the Project? What Category do the Metal Studs belong to? Or, are you trying to determine individual Stud information from overall length and height of compound-layered Basic Wall Types?
Yes, Curtain Walls could be used as well with Studs as Mullions.
Message 4 of 22
L.Maas
Depending on what you have available in your project exactly (e.g. families, parameters).
You can add a formula to a schedule. Other option might be to add one or more parameters with relevant values to your families. Also dynamo might be an option to assist with the calculations.
Maybe you can upload relevant part of your project so that we can have a look and  have a better understangdng of your situation.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 5 of 22
I need the overall length of the studs. I don't care much about how I achieve this, with model or with formula just as long as the end result is the total length in linear foot. Do I modify a curtain wall?
Thanks.
Message 6 of 22
I'm trying not to use Dynamo, reason because I don't have any experience. Is there a way to include the length of the Metal Stud in the model so when I schedule it will automatically appear.
Thanks!
Message 7 of 22
cbcarch
You could:
Make a custom curtainwall, with custom "stud shaped" mullions. Set them at 16" or 24" on center per your req'ments.
Then create a Schedule of Mullions by the "stud" type mullion. This will give you quantity and lengths of the "stud mullions".
Edit: But just because you "can" doesn't always mean you "should"! As this would not be a practical way to develop your walls. The Schedule with Area/formula and calculated value is probably more appropriate.
See this: https://forums.autodesk.com/t5/revit-architecture-forum/material-takeoff/td-p/7058980
Cliff B. Collins
Message 8 of 22
Thanks!
Yes there are several approaches depending on your workflow.  It's not difficult. Where are the studs coming from?Are they actual instances in the project or you trying to calculate quantities/lengths based on a spacing divided by distance. What kind of schedule are you working with (Parts, Walls, Curtain Walls, yada, yada...)?
Message 9 of 22
@Anonymous
There are three approaches:
1. Use a formula to calculate the studs based on the wall linear feet and height.  This is the old school way, not very accurate when you have fenestration and sloped roofs but maybe acceptable practically.
2. Model the studs and schedule them using curtain walls or adaptive components.  Either way, the studs should be modeled as a separate entity from the walls.
3. Pay for an add-on and have it do it for you.  Example:
http://www.aga-cad.com/products/bim-solutions/wood-framing-wall
Message 10 of 22
...or https://strucsoftsolutions.com. Around $4000.  Smiley Wink
Message 11 of 22
Thanks for the reply,
1-I managed to get it to work with a formula but I want to generate using model.
2-As for the second solution how can I make the mullion to show as linear feet, more precise how can I put the formula inside the mullion. I created it as a new family, with the desired profile, but I don't know how to put the formula.
Below are 2 pictures, in the profile in the family types properties there is a "Height" do I put the formula there. I'm a bit confused.
Thanks!
Message 12 of 22
Good solution but, my settup costs way less than that Man Sad
Message 13 of 22
@Anonymous: Isn't this about Scheduling? If so why are you needing the formula in the Family? Put the formula in a Calculated Parameter Field with the Schedule.  However, I'm not sure  why you even  need it.  Sounds like renaming the column named "Length" to "Linear Feet" would suffice.  And, you don't put the formula inside the Mullion; it's just a 2D Profile. But, CW Mullion Schedules will itemize Mullion lengths (aka: "Linear Feet").
Message 14 of 22
 Thanks! One more thing tho, how can I use a formula in the schedule which has length in feet and count as a number, because I cant use Count in the formula. I'll attach a snip. Thanks!
Message 15 of 22
Assuming your stud spacing is 16" o.c. then add a Calculated value parameter, type = Number, name = Quantity, and enter in the formula box:
roundup ( Length / 16")
Format the field to Calculate total.
Message 16 of 22
Not sure I understand. The count isn't really germane. The Length (aka Linear Feet) of those units it what you're after, I thought. If your studs are purchased in 8'-0" lengths, then to find the total number of 8'-0" studs needed for the job, you'd write the number formula: (Length/8'-0") and Calculate Total (under Formatting tab).
Message 17 of 22
Just one thing though, maybe I didn't clarify, the Length is the length of one Mullion (or the height of the wall) so my wall in 20' and there are 148 vertical Mullions @ 16 OC with Height of 20'.  That's why I want to calculate (20' x 148 = 2960') but in schedule the Count doesn't show up in the formula options. Thanks!
Message 18 of 22
@Anonymous wrote:
@Anonymous one thing though, maybe I didn't clarify, the Length is the length of one Mullion (or the height of the wall) so my wall in 20' and there are 148 vertical Mullions @ 16 OC with Height of 20'.  That's why I want to calculate (20' x 148 = 2960') but in schedule the Count doesn't show up in the formula options. Thanks!
You don't need a formula.   Add a Calculated value parameter (type = Length) and name it Total Length.  Enter in the formula:
Length
Go to Format tab and set the Total Length field to Calculated total.  It will report the total Length
Message 19 of 22
I just need the total length of metal studs in a project. There may be 1 floor, 5 floors sometimes 12 floors, the Height differs project to project. I don't know if they buy the studs at 8' or 10'. I know I can later in excel calculate the totals, but I wanted to know why I can't use a formula because I have the Length of the Mullion and the Total Number of Mullions. It's not only for this project, I just wanted to know why I can't multiply a length with an integer/number.
Thanks.
Message 20 of 22
Thanks, that did it.
