Scheduling IFC Parametrs
2 REPLIES 2
mzurek
1025 Views, 2 Replies
Does anyone know if it is possible to make use of some of the IFC parameters that come though in an import into Revit?
I can see lots of great data in the properties of an IFC imported object but I cannot find a way to schedule it. Any suggestions?
2 REPLIES 2
TripleM-Dev.net
in reply to: mzurek
You mean when a IFC is linked in a Revit project?
The parameters are added as Shared Project parameters by the IfcImporter.
There should also be a file generated with the RVT: <IfcName>.ifc.sharedparameters.txt
Use this to create the needed shared parameters in the Host project file.
The use schedule as normal with "Include elements in links" on.
As long a you leave the <IfcName>.ifc.sharedparameters.txt where is and reload a updated IFC it should use the same shared parameters I think (never tested)
mzurek
in reply to: TripleM-Dev.net
That worked... thanks so much for your help!
