Floor and Wall join
10 ANTWORTEN 10
Nachricht 1 von 11
468 Aufrufe, 10 Antworten
Floor and Wall join
Hi! I'm trying to figure out how to join walls and floors properly. I kind of want the finish layers to "meet". You can actually "cheat" it by painting the structural surface, however it leaves a line which is visible not only in 3D view but also in 2D. Please see attached photo for reference.
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Anonymous
Are those actually floor and walls?
Anyways, here's some bedtime reading for you. The good part is at the end. SPOILER ALERT: Boy and Girl live happily ever after.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Nachricht 3 von 11
als Antwort auf: barthbradley
Yes those are floors and walls. It's just a visualization of what I'm
trying to achieve, which I can't.
Nachricht 4 von 11
XXalessio.amodioXX
Brutally.
Modify>View>Line Work>Invisible
Nachricht 5 von 11
als Antwort auf: XXalessio.amodioXX
Yeah I guess this is the only solution. It sucks though because you have to do it in every view.
Nachricht 6 von 11
bin
You need to think about how it is going to be built.
Nachricht 7 von 11
XXalessio.amodioXX
Mark my answer as solution if solved the issue
Nachricht 8 von 11
Samantha-G
Hi @XXalessio.amodioXX
Have you tried unlocking the finish, and just extending it along the floor?
Please see the link below:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Sam G, CM-BIM
Revit Certified Professional
Nachricht 9 von 11
Nachricht 10 von 11
XXalessio.amodioXX
als Antwort auf: Samantha-G
Hi
Thanks for the tip but I usually try to model the Finishes as separate layer to have more control e.g. around window,joinings.
Nachricht 11 von 11
That is exactly what I'm doing. That "wall" and "floor" is supposed to be a 25mm plaster with a thin layer of paint.  That pic demonstrates how I treat wall openings, basically a "floor" for the sill, "walls" on the sides and a "ceiling" for the upper part. The problem is you can't clean join a floor and a wall, it leaves a line when joined. Anyways, linework seems to be the only solution as far as I know.
