Schedules not Updating
As seen in the attached screenshot, Revit does not update the gross area schedule. On the left we see a seperate .RVT file that is linked in on the right. The link is saved, closed, and reloaded into the file on the right. The schedule does not update.
Thanks Revit.
What do I do?
Cut and paste the schedule aligned in place?
I feel your pain. We've noticed the same thing happening in our 2019s. Close and reopen resolves for us. I suspect a hotfix will be coming down the pike.
the worst part of this is that I removed the link, and when added back in, it is still pulling the outdated information. In the linked file, there are two area types, and not the one listed 'CR-102' isn't found in the original linked file anymore.
Revit was pulling rentable area information instead of gross. I found this out by creating a rentable area view and found that someone before me had started and later deleted the rentable area view, creating the anomaly. Fix: -create both rentable and gross area views in addition to double checking existing views while searching for the anomaly
