Schedules need to read linked text parameters too.
Message 1 of 27
According to "About Linked Models in Schedules" Schedules do not currently support text boxes.
I have a project where I need to keep a master list of sheets and list which bid package each sheet is in.
First, I set up yes/not parameters in each model for the sheets. Then I set up a second formula parameter to convert the Yes, or No to a Dot symbol. The formula text parameter will not read the yes/no parameter set in the linked model.
A-450 and A451 will be moved to a different category later, but for this example you can see that the dot isn't showing up for those two linked line items.
If there's already a way to get linked files to work like this, please let me know.
Replies (26)
Message 2 of 27
TripleM-Dev.net
It should work, are you using the same Shared parameters for the Yes/No.
Below a sample, it converts the Yes/No of "test_yesno" (shared parameter) to Ok/No and dot/empty
- Michel
Message 3 of 27
Can you elaborate? How did you "set up yes/not parameters in each model for the sheets"?
Message 4 of 27
You need to use the same shared Yes/No parameter in linked files and main file, assigned to Sheets category. In the main file, edit the sheet schedule and tick 'Include elements in links' box under Fields tab..
Message 5 of 27
Yes, I am using the same shared parameter. The files are located on BIM 360. Does that make a difference? We are using the same titleblock family in each model, same shared parameter.
I created a shared parameter in the main model, added it to the sheet family, then added the shared parameters to the linked files. I then added all the info to all of the sheets where it needed to be, then it doesn't work when I link it back in.
This is the file once it's linked.
Message 6 of 27
Yes, "include elements in links" is checked. Otherwise the sheets themselves wouldn't show up.
Message 7 of 27
The issue is clear: the IF statement is not reading the yes/no parameter of the Link.  How did you "set up yes/not parameters in each model for the sheets"?
Message 8 of 27
This is what I did in each linked file and model first.
1. Manage -> Shared Parameters -> Select Sub Category (Sheets) -> Click "New" under "Parameters"
2. Name shared Parameter -> Set Type to "Yes/No" -> Repeated to get BID PK 2-4
Then I went to family, made sure shared parameter file is linked -> Add new instance Family Parameter as shown below. -> load titleblock family into all linked files and main model.
Is there something I missed in this process? This is also a project on BIM 360.
Message 9 of 27
Category Sheets??? How is that supposed to work in the Parent Project?
Message 10 of 27
Yes, the shared parameter was set to "Sheets" category. I can't find that option now that I'm looking through it though.
Message 11 of 27
TripleM-Dev.net
Little side note to the use of YesNo:
If not used (not initialized) it has actually no value the grey checkboxes haven't been used!
It can't evaluate True or False statement, en so it's left empty.
Sample of not - initialized YesNo, make sure it actually on (black and not grey) or off.
Message 12 of 27
Can you unhide the yes/no fields of the schedule and share the screenshot?
Message 13 of 27
Sure,
Is this a process that doesn't work for BIM360?
Here's the part of the schedule in the main model that has the linked files.
I have 2 bid package parameters. The first 4 is the yes/no parameter, the second 4 converts the "yes" or "no" into a dot symbol. The yes/no parameter and the dot conversion both work for the sheets in the main model, but not for the linked files.
These are the sheets that I didn't need to link:
Message 14 of 27
How come the first 4 columns of screenshot 1 are empty?
Message 15 of 27
Exactly, It won't read it! That's the problem.
Message 16 of 27
For example, I clicked on I-452 and selected 3 & 4.
Then I synced to central, published the model, and reloaded into the main model.
I tried closing out of the linked models and it still will not link this information.
Message 17 of 27
Wait a minute.  What family?  You are supposed to add the Y/N shared parameters to each of the projects, not family.  No family should be involved in this process.
Message 18 of 27
Assign the Shared Parameter to RVT Links Category.
Message 19 of 27
But, it wasn't a parameter that was already in the family...so I wouldn't have a way to add click the yes/no parameter for each sheet unless I added it to the family.
Message 20 of 27
You keep saying family.  What family are you talking about?
You need to open each project, go to Manage > Project Parameters > Add > then pick the Shared parameter you created in the 1st step and assign it to Sheets category.  Repeat to add all 4 shared parameters.
