schedule Spot coordinates
i need to schedule Spot coordinates X,Y,Z for a wall (revit architecture)
any idea ??
A typical wall has 8 geometry defining points (corners). Not sure if they are what you are referring to as spot coordinates?
i want to create a schedule for coordinates in walls corners ( X,Y,Z)
can i do this in revit architecture??
As far as i know, you can not schedule coorinates in revit without using a plugin.
Most likely you need to develop a plugin yourself or get one from the net 😞
example for one of these plugins: https://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3Apillecoor...
As far as i know its free (and not only a trial) app
Keith_Wilkinson
In the past we've used the Excitech toolkit to schedule coordinates but I'm not sure it would work on spot coordinates (we've used it for pop up locations using a custom family).
http://www.excitech.co.uk/products/Revit-Toolkit.asp
Be warned though, as far as I'm aware any plugin that accesses this data needs to be rerun to update any changes - ie it's not automatic.  I would also recommend that you test thoroughly before using it for production info.
K.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
loboarch
You may want to take a look at Autodesk Point Layout.
http://www.autodesk.com/products/point-layout/overview
Jeff Hanson
Principal Content Experience Designer
Revit Help |
