Schedule Split on Sheet has Extra Title Block
Message 1 of 19
I've split a door schedule over multiple sheets and into two columns within each of the sheets. Although it was split into two columns, there is a third title block with no rows below it adjacent to the schedule. I can move it off the sheet, however I have to set the print guidelines different from the rest of the set or it will try to print the full extents including the extra title block. How can I get rid of this third block?
Replies (18)
Message 2 of 19
Not following...Are you saying you have 3 fields defined in your schedule, and you only want to display 2 of them. If so, make that third field a Hidden Field.
Or...are you saying that you have 2 header fields with nothing showing under them. Is so, grab the blue dot at the bottom of the adjacent columns and nudge it down a little.
Message 3 of 19
Please see the attachment. All fields have been duplicated with no info below
Message 4 of 19
Message 5 of 19
Grab the third column by the arrow symbol (op left of the column) and drag it on to anther column.
Message 6 of 19
Arrow symbol? You mean the blue dot, don't you?
Message 7 of 19
Nothing attached
Message 8 of 19
Take a look at the attached screenshot
Message 9 of 19
Yep, do what I said. That'll work. BLUE DOT.
Message 10 of 19
Pulling the blue dots down in either section of the schedule with doors didn't get rid of it and the section without door info doesn't have a blue dot.
Message 11 of 19
Actually, grab the move icon on the rogue headers and drag it to the left. Sorry for the misinformation.
P.S. Sorry @ToanDN, I thought you were referring to the blue down arrows. I see now that you were referring to the move icon (also arrows).
Message 12 of 19
I moved the extra header over the left most section header and it seems to have disappeared! Thanks!
Message 13 of 19
Give the solution to @ToanDN
Message 14 of 19
Message 15 of 19
Seychellian
Thanks man. This worked for me
Message 16 of 19
TCAOffice
This didn't work for me.  I have two extra headers/titles floating beside my schedule and they won't go away.  I've drug the 4-way arrow onto the adjacent schedule.  It tells me it can't resize the column and cancels out.  Any thoughts?
Message 17 of 19
Don't know if you're still having the problem, but I thought I was having the same issue. You need to zoom in enough to be sure to grab the 4-way arrow handle. If not, you end up grabbing one of the column resize handles. Grabbing the move handle, and dragging the "rogue" header onto a correct header works.
Message 18 of 19
anielson
FYI, I thought this wasn't working for me, but it turned out I had like 5 "rogue" schedule headers stacked on top of each other and just had to drag the grip multiple times to get rid of them all.
Message 19 of 19
afrueh8AB4L
I dragged the empty columns by the arrow button to the bottom of the adjacent column and it disappeared
