Schedule row height adjustment?
james
james
Seems it's been impossible to adjust the schedule row height w/o increasing the font size since forever (so there is more white space in the rows), but wondering & hoping there is a recent trick out there that I haven't been able to find.
  1. Create a new Calculated Field (Type = Text) in the Fields tab of the Schedule Properties.
  2. Select the column letter of the newly created column, so that the entire column is selected.
  3. Right click on the column letter of the newly created column and select Edit Font.
  4. Set the desired size of the font.
  5. Click OK.
james
Thanks for the clear instructions!  I found this earlier, but the Calculation field wasn't clear.
It's been on the "Wish List" since Moses wore shorts.  Smiley Frustrated
Maybe I misunderstood you. You want to everything aligned Horizontally and Vertically? Yes, you can do that.
mary.schmitz-dex
And if I do not want to see that column?  What happens?
