Schedule Properties - blank row height
arkitek2ss
Message 1 of 12
arkitek2ss
Replies (11)
Message 2 of 12
You can't. The Variable box is not for control the blank row. They are just co-incidentally next to each other.
Message 3 of 12
arkitek2ss
OK, thank you.
Message 4 of 12
You can get there through Title and Header and other formatting tools.
Message 5 of 12
ahannerX5E95
@barthbradley   Is it possible the enlarge the size of the blank space before data?   When you say edit formatting tools like Title and Header, where is this editable?  I only see the option in the Appearance tab, but I don't see that it is possible to change the size.  Thank you for your help.
Message 6 of 12
ahannerX5E95
This is what I am trying to recreate  @barthbradley
Message 7 of 12
There is no blank row in the picture so you can just untick Blank row before data box in Appearance tab.
Message 8 of 12
ahannerX5E95
@ToanDN
Thank you for the reply, but the picture is showing an excel spreadsheet that I was going to recreate with detail lines and text, if I could make the blank row before data large enough to fit it all.  If it's not possible, I may just make the schedule in a drafting view, but I am open to suggestions.
Message 9 of 12
@ToanDN
You can make a Revit schedule look exactly like that easily with:
- Format tab: select fields and set Vertical header
- Select multiple column headers and Group and type in column grouped header
- Sorting/Grouping tab: sort by Level and add Sorting header
There is absolutely no need to add a tall blank row to fake in the information.
Message 10 of 12
ahannerX5E95
Well, that is neat.  Thank you!  @ToanDN   🤯
Message 11 of 12
ahannerX5E95
@ToanDN   I am not able to complete this step.  I thought I followed along, but nothing displayed vertical or grouped under a header.  Sorry for the confusion.
Message 12 of 12
Select multiple column headers and Group to create a Group Header
Select Fields and format Heading Orientation.
How schedule looks when placed on Sheet.
