Schedule apartment types by floors
Pierluigi.Glicea
Message 1 of 16
Pierluigi.Glicea
I'm trying to create a schedule that would summarise the apartment types. This would make our client's life easier.
I'm attaching a picture to clarify my intentions.
Can anyone help me with this? I'm struggling with the apartment types counts.
Thank you very much
Replies (15)
Message 2 of 16
Post your Project file here as an Attachment to a Reply Post.
Message 3 of 16
Yes it can be done easily with Room or Area schedule, depends on what you use to define apartments in the model.
Message 4 of 16
Pierluigi.Glicea
Thank you for your reply,
I don't have a project to show you at the moment since I'm creating a template that would suit the office's future needs.
Message 5 of 16
Pierluigi.Glicea
Could you please explain how to manage the columns to me?
Much appreciated and thank you for your time
Message 6 of 16
Well then, all's I can say is that it can be done.
Message 7 of 16
I can if you share a sample model with some apartments.
Message 8 of 16
Pierluigi.Glicea
Thank you! I'll create an example and link it here if it's ok with you.
It won't be a real project but I believe it will suit our needs.
Message 9 of 16
linkboy
@ToanDN
I have a similar question, made a sample model attached. Below is the schedule try to work out, added % to show each type unit vs. all units. thank you,
Message 10 of 16
Something like this.
Message 11 of 16
linkboy
Can we combine 1BR-A + 1 BR-B = 1 BR?
Message 12 of 16
I would use 1 BR for name and A or B as Comments.
Message 13 of 16
linkboy
That works for me! Thank you @ToanDN  . I did not start the post, cant accept this as solution.
Message 14 of 16
Pierluigi.Glicea
The schedule you attached is exactly what I'm looking for.
I would like to have unit types on columns and levels on rows if possible.
Message 15 of 16
linkboy
I have units #, area and ADA requirements in the schedule, but not able to switch the row/column of the matrix. Like to see that happen, not feeling it is necessary.
Message 16 of 16
Pierluigi.Glicea
unfortunately I really need to switch between columns and rows as I showed before.
Hope someone could help
thank you
