scalelabel does´nt work, wrong parameters?
oskar.fahlen
oskar.fahlen
Hi! I have some trouble with my sheets..when i put views into my sheets the sheets doesnt automatically add what scale the views are. I guess it has to do with some parameters? the only way ive manage to se the scale is in inches but i want it in metric..
Are all the views having the same scale? If not then the sheet will show As indicated.
oskar.fahlen
The views have different scales. It doesnt show As indicated, it doesnt show anything at all. All the info i want from my views gets added to the sheet except the scale.
curtisridenour
If the Label in the title block family is not set up correctly, use the method shown below.
Share you titleblock family here.
Huh?
Something doesn't add up here.  I got to see this.  Post your Project (RVT).
