SCALE PARAMETER IS DELETED FROM THE FILE
afrancis7XSXC
Observer Observer
afrancis7XSXC
Observer
Observer
SCALE PARAMETER IS DELETED FROM THE REVIT FILE , I TRIED TO REMAKE THE PARAMTER BUT IT IS NOT READING AUTOMATICLY FROM THE LABEL ASSIGNED IN THE SHEET , CAN YOU HELP TO RESTORE THE ORIGINAL PARAMETER TO THE FILE TO READ IT AUTOMATICLY ONCE AGAIN
THANK YOU
jay_colcombe
You could load in a default Title Block from the Revit Family Library > Title Blocks, edit this family and Copy the default label to the Clipboard, then open your Revit title Block and Paste from Clipboard into your Titleblock and save.  This will ensure you are using a default label you know works!
You then need to remember if you have a Revit Template you always use you need to update it with the updated Titleblock
Jay Colcombe
Autodesk Certified Instructor
I don't understand what you are asking or showing.  Your top screenshot is showing the view Scale label on the Sheet Titleblock circled in red. Your bottom screenshot is showing a list of Project Parameters. One has nothing to do with the other.  The view Scale is a label (with special powers) that is created and placed inside the Titleblock Family.
afrancis7XSXC
Observer
Observer
the label in the title block in showing correctly , but the scale is not showing in the drawing list schedule , the scale parameter is deleted from the entire project , that's why i am showing a screen shot from the project parameters , i tried to recreate the scale parameter inside the project but the label and the new parameter are not linked together any more
afrancis7XSXC
Observer
Observer
the scale parameter isn't linked with title block label any more that's why the drawing schedule not showing the scale in the schedule , can you advise how to solve it
jay_colcombe
The Scale Parameter is not available for Sheet Lists!
It is available for view Lists as it is View Specific
Jay Colcombe
I don't understand what you are Scheduling. Titleblocks???
First, you can't directly, but maybe you can via Dynamo.
Second - and foremost - if you had Multiple Views of different Scales placed on Sheets, that "Scale" Label would read "as indicated".   Is that what you are after?
