Saving a project as a template
kherrman
kherrman
Autodesk says I should be able to remove work sharing from a project and then be able to save the project as a template. I do this but the save as template option remains greyed out.
Tom_Kunsman
You will need to save the file as detached from central , and remove all worksets as template files can not have worksets saved in them.
How did you remove worksharing?  Open detached and disregard worksets?
Tom_Kunsman
@ToanDN yes, disregard worksets (which I think is the bottom option)
