Same wall type but displaying differently
tcaratellaBU7PE
tcaratellaBU7PE
Hi All I'm new to Revit. I have the same wall type in my project, however both are displaying differently. I have tried matching properties, phasing is the same and there are no graphic over rides applied. Ho can make them both display the same? I did not create the original model - I have two house type brought in from two separate models into one new file. Please see attached.
L.Maas
Not clear from the screenshot what is going on. Maybe you can upload the file(s) so that we can have a look.
You might need to strip the files down to the relevant parts to decrease the filesize (max upload is around 75 MB)
Louis
Please mention Revit version, especially when uploading Revit files.
tcaratellaBU7PE
Hi, here is a copy of the file.
Sahay_R
Is this saved in 2018?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
tcaratellaBU7PE
Yes this saved in 2018, however I brought in 2 models from 2017 and put them together - could the merging of the two models from 17 into one 18 version be the probelm?
L.Maas
No, there is difference between the two walls.
One has the top attached, other does not
After detaching it starts to look the same
Louis
tcaratellaBU7PE
Thanks that's great it worked! I was wondering why it was greyed out, but then realised I had to attach it to the top wall.
