Same Material Drafting Cut Pattern not Aligning between 2 Walls
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a bit of an odd graphics issue.
I have 2 walls that are stacked on top of each other and the plywood pattern for the sheathing is not aligning between the 2 wall types. The material is the same for both elements and the thickness and locations are the same as well as the function and location in the wall assemble structure.
I have restarted my Revit and my computer, remade the section, turned on and off hardware acceleration but to no avail.
From my understanding, drafting patterns originate at the project origin so they should always line up if you are looking at 2 elements with the same properties and orientations.
