Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Rvt vs Rte. - Whats the difference?
JKspace424
Message 1 of 9
JKspace424
Was working in rvt file but for some reason it turned into an rte file.
1.  Does it make a difference?
2.  If so how do I turn it back to an Rvt file?
3.  What is rte file for?
Replies (8)
Message 2 of 9
Message 3 of 9
Yes.
Save and close the RTE.  Start a new Project and choose From Template then browse to the RTE.  Save the new project and it is your working file from now on.
Revit Project Template.
Message 4 of 9
JKspace424
Thanks for the answers.  What are the benefits of using rte file?
Message 5 of 9
You always use an RTE. Architectural, Construction, Structural, Mechanical are all RTEs
...Revit uses Templates in Families as well.  When you create a new family, Revit prompts you to select the Template to use. Generic Model, Generic Model Face Based, Generic Model Wall Based etc. are all Templates.
Message 6 of 9
RTEs are Revit Project Template files.  When you start a new project you can choose from one of the pre-existing RTEs and inherit everything in that template.  Revit comes with a few ones such as shown below:
Message 7 of 9
rudy.delacruz
Please,
I want that send me file IFC Metric Template.rte
THX
Rudy
Message 8 of 9
kh_jea
"IFC metric template.rte" doesn't exist.
You already have "Metric Template.rte", as it is installed by default.
Message 9 of 9
@rudy.delacruz wrote:
Please,
THX
Rudy
"(Optional) Before opening an IFC file, use the Import IFC Options dialog and select a default template to use for IFC files.
Note: If a default template is not selected, the first template listed under File Locations in Revit Options dialog will be used."
