RPC's are not working in Revit Architecture 2017
Message 1 of 25
I just installed Revit 2017 from 2015, so I loaded a previous project to see the new rendering capabilities and none of the trees or people are rendering, In fact most of them just show as blocks or cubes. I even loaded a new project and new families straight from the 2017 templates folders and I still get the same results. I believe it has to do with running previous versions of Revit on the computer, yes I installed 2017 before removing 2015 I've attached files to help clarify things
Accepted solutions (4)
Replies (24)
Message 2 of 25
aRcHiTeCt.JM
You need to copy again your entire RPCs library in REVIT 2017.
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2017\assetlibrary_base.fbm\RPCs
If you don't have the RPCs folder... create one and copy-paste all content
Then everything will be alright.
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 3 of 25
This didn't work, all the files seem to be there...
Message 4 of 25
aRcHiTeCt.JM
Then maybe:
That's because Archvision did not release the 2017 version of their products compatible with Revit 2017....
for the current 2016 release and its predecessors see THIS LINK HERE
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 5 of 25
I forgot to mention that im just using the stock RPC's that come with revit. it seems to me that the link in revit is somehow broken to the location of the files. or maybe it has to do with the registry of the computer...im working on windows 10.
Message 6 of 25
Try reloading all the RPC trees from the 2017 library...
I just tried it with my 2017 (on Windows 10) and it works just fine.
Message 7 of 25
I uninstalled Revit completely and reinstalled and not its saying "rendering feature are currently disabled. you must install the rendering library to use rendering features"
I've uninstalled and reinstalled Revit 3 times since then including everything associated with Revit and i still get this message...
Message 8 of 25
Sounds like your material libraries are not getting installed.
Message 9 of 25
aRcHiTeCt.JM
go to:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
or... are you installing REVIT 2017 connected online?
because for all libraries to be downloaded you need to be connected.
don't use firewall...
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 10 of 25
ive downloaded it to my harddrive then im installing from there
Message 11 of 25
Hi, could you solve the problem with the renderings? I've exactly the same problem.
Cubes instead trees and people.
Thank you
Message 12 of 25
awalker123
Observer
Observer
I am not sure what you mean by "You need to copy again your entire RPCs library in REVIT 2017" copy what again? I copied it, now what?
The library is in this location already C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2017\assetlibrary_base.fbm\RPCs
I don't need to create it.
The trees show up as gray blocks.
Please help!
Message 13 of 25
Has anyone solved this issue? I´m having the same problem here....RPC files are installed, but trees oly show as white boxes
Message 14 of 25
Don-83
I have the same problem. Has this issue ever been fixed?
Message 15 of 25
Don-83
Copy from where??
Message 16 of 25
melissaJCNY4
I'm having the same issue...did anyone find a solution for this?
Message 17 of 25
With 2017 I installed this and it worked,,,
Message 18 of 25
melissaJCNY4
Thank you. I tried that, and it didn't fix my problem unfortunately.
Message 19 of 25
Message 20 of 25
melissaJCNY4
Yes. I installed and updated and it still did not work/change the plantings.
