Round dimension?
Round dimension?
nfiorentinoUXTB2
Round dimension?
nfiorentinoUXTB2
Is it possible to select one single dimension from a dimension string and round to 1/4, for example? Where can I access the dimension properties for each dimension?
Sorry, I am a very beginner. Thanks.
nfiorentinoUXTB2
Got it.
https://hyperfinearchitecture.com/top-12-revit-dimensions-tips/
There are some instances in which you want a rounded dimension. If that’s the case, select your dimension and Edit Type. Duplicate to create a new type and give it a name that makes sense. Scroll down, look for Units Format, uncheck Use Project Settings and at rounding select the level of detail you want.
