Rotation of generic annotation at sectiton/elevation views
12 REPLIES 12
Message 1 of 13
denisyukJ
561 Views, 12 Replies
I need to mark all elements at section/elevation view, but here is an issue: some tags should be rotated according orientation of the element.
I have tried to:
1. Insert tag inside the family, but this method doesn't work for section/elevation views.
2. Make a tag supporting roration fuction, but this method doesn't work only as type parameter.
Can some of you give me advise how to solve this question?
12 REPLIES 12
Message 2 of 13
in reply to: denisyukJ
Rotate Tag in Project View.  😉
Message 3 of 13
Edit the tag family and set it to rotate with element.
Message 4 of 13
denisyukJ
in reply to: ToanDN
@ToanDN
Could you be so kind to explain how to implement this method?
Message 5 of 13
denisyukJ
in reply to: barthbradley
@barthbradley
Tag is not rotateable in section/elevation view, isn't he? Only vertical and horisonal positions are available.
Message 6 of 13
Use the Rotate tool.
Message 7 of 13
denisyukJ
I've tried, but it doesn't work for me.
Message 8 of 13
No like issue here.  I can rotate a Tag in Elevation/Section.
Edit the Family and see if changing the status of Rotate with Component and/or Keep Readable Parameters helps.
Message 9 of 13
What version of Revit?
Message 10 of 13
denisyukJ
2021
Message 11 of 13
denisyukJ
I have tried different variations of these parameters, it dorsn't work as well.
Message 12 of 13
Do you have a drop-down with Horizontal, Vertical and MODEL showing on the Options Bar?
Message 13 of 13
Nevermind. I just checked. 2021 doesn't have Model so Rotate won't work.
