Im new to Revit and using Revit 2022. The wall and floors that I created are not showing up on the second level floor plan. Although they show up on all other levels. Have tried adjusting view range, but it didnt work. Any ideas ?
Thanks CMaggard
Gelöst! Gehe zur Lösung
Gelöst von clarkpmike. Gehe zur Lösung
Looks like the wall and floors are below Level 2. Set your View Range Bottom and Depth to "Unlimited" and see if they become visible in the Level 2 View.
FWIW: Here's a good reference to keep handy for occasions just like this:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Could be something as simple as you're not zoomed out far enough? Try Zoom Fit - ZF
Might have an item on the second floor level that is way outside your plan. In your second floor view type ZE, then do a crossing (lower left to upper right) from the one corner to the other and see what is selected. If two areas have something selected then you have a wondering component.
I am having the same problem. I have been designing a few models of small two-story homes and for some odd reason on the last project, nothing shows on the second floor. I already tried everything and nothing seems to work. The outside walls go all the way to the top of the second floor and even those don't show. I tried selecting a wall to see if something highlights on the second floor and nothing.
I created this last project exactly like the previous ones and none of them have this issue.
I will appreciate any suggestions.
@maurice.garlet wrote:I am having the same problem. I have been designing a few models of small two-story homes and for some odd reason on the last project, nothing shows on the second floor. I already tried everything and nothing seems to work. The outside walls go all the way to the top of the second floor and even those don't show. I tried selecting a wall to see if something highlights on the second floor and nothing.
If none of the info in this thread is helping, then I would suggest posting your RVT file here and letting us examine it. That's the quickest way to get an answer instead of guesses.
Do you know how to post your file here? Start a reply post, scroll down to "Attachments" and press "Browse".
I had the same problem when starting a new project with the imperial construction template. The Phase on Level 1 is set to "Project Completion", meanwhile, the phase on Level 2 is set to "B10 Superstructure". To display the walls in this case, change the phase filter on level 2 or any other problem level to "Project Completion"
