Rotating texture on curved wall
4 REPLIES 4
dicky
2299 Views, 4 Replies
Materials can be rotated by tab selecting the hatch and using RO to rotate on flat walls, however if the wall is curved rotating the hatch pattern does not work (given I have tried creating an elevation view at the tangent of the mid point of the curved wall).
I am trying not to get around this by duplicating the material with a rotated texture as that will create too many duplicates, am I missing a step with the first method or is there some other way?  Many thanks.
Labels (5)
4 REPLIES 4
RDAOU
in reply to: dicky
@dicky
If it is curved pattern cannot be rotated => a workaround is a must. What kind of workaround depends on what you are modeling and how many rotations (image shows 2 1 vertical and one horizontal). There are several workarounds...example:
  1. Split face and use paint tool to apply 2 materials with different patterns
  2. Create a custom material with a custom rotating pattern
  3. Work with curtain walls...Panels can be basic walls and you can use 2 types of basic walls with different patterns
  4. Work with pattern based curtain panels
in reply to: dicky
Textures between should match unless you manually rotated the texture on the flat walls.   Or are they already mismatched from the get go?
dicky
in reply to: ToanDN
Thanks ....The texture map is horizonal, and I have already rotated the 2 flat walls on either side of the curve, hence the curve part is the only portion left that is still horizonal.
in reply to: dicky
Then assign a material suitable to the curved wall and you shouldn't need to rotate anything at all.
