Rotating steps
Rotating steps
russell.beale
Rotating steps
russell.beale
I have created steps in Revit between two points ( top and bottom of embankment) but the angle is wrong, is there a way to change this? see below a screenshot of what the steps look like when in combined model. I kind of want to change the steepness of the steps as as such.
thanks
georgehobel
looks like the stairs are doing what you have asked them to.. they are getting you from elevation 1 to elevation 2.  in order to stretch them out for a more shallow angle... you will need to adjust the length of the run for each tread.
George Hobel
Reflections of Charlotte
Residential Building and Design
There is a parameter for minimum tread depth when you create the stair.  This needs to be increased for the slope to be more shallow.
