Rotating Patterns
Rotating Patterns
jfjacques
Rotating Patterns
jfjacques
I can rotate a model hatch pattern by selecting it in a view and rotating.
How can I rotate a model hatch pattern itself?
This way I don't have to rotate all it's instances in the project?
I thought I could select all hatches as a workaround, but that doesn't seem to be the case.
Come to think of it, is there a way of selecting all hatches?
If it was created within Revit you can edit the fill pattern type.  If it is a custom pattern you have to modify the information in the revit.pat file.
Are you wanting a different hatch or a different orientation to host? If you change the material's hatch pattern to Drafting, you might be able to achieve what you're looking for by changing its "Orientation in Host Layers".
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
