Revit Titleblock and change papersize
3 ANTWORTEN 3
Nachricht 1 von 4
bozandilistan
2508 Aufrufe, 3 Antworten
Hi all,
When i define label for height and width in titleblcok to change the papersize in my projects, the images or text notes are not compatibel with that change. I should align them also with kinda parameter but dont know how.. or i have to create seperate titleblcok families for each size, withouth height-width label. What is ur method?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: bozandilistan
Are you talking about different sized Title Blocks in the Sheet View? If so, create a separate Title Block Family.
...are you talking about parametrically changing the size/scale of Text?  No can do. But you can have 2 different sized text in one Title Block and control which one is Visible through On/Off parameters.
Nachricht 3 von 4
bozandilistan
Thank you, i never think visibility, i willl try
and i entered some rules, create a group with jpeg and lines, but jpe g did not move with these lines. is there any way to move them together?
Nachricht 4 von 4
Load the Image into another Annotation Family and nest that family into the Title Block. This way, you can pull labeled dimensions to and from it.
