Rotating parking tags?
Is there a way to rotate parking tag instead of using defined vertical/horizontal orientation? It's absurd it's so hard to do. Normally there's a special option "model" for tags (still silly if you ask me) but it's not there for parking tags.
RobDraw
It might be silly of me to ask or even absurd that you might not have checked this but have you checked this?
Rob
Corsten.Au
Hi
You may use a nested annotation family in parking and control the numbering of parking using
instance parameter which maps " annotation family " instance parameter ( text of number. )
this way you can rotate the parking family in any angle ..
nested instance parameter " annotation family "nested instance parameter " annotation family "
Corsten
Building Designer
@RobDraw - Yes I did. It does not work as expected nor it does let me rotate the tag as I'd like to any regular element. No need for sarcasm if it doesn't help.
@Corsten.Au - Thanks. Just as I thought - no "regular" way to do it but it does push my case forward.
RobDraw
@Anonymous wrote:
@RobDraw - No need for sarcasm if it doesn't help.
I was just following suit. You weren't being sarcastic?
What is this case you are pushing? I thought you were here for help.
Rob
