Rotating Mullion
Rotating Mullion
Rotating Mullion
Greetings,
I've been doing a porject, and I wish to rotate the grids of my curtain panels to be parallel to the level line. I've tried but I can't get an exact rotation degree and it is not alligned. What can I do to solve it? I'm attaching a picture
Thanks in advance
rodrigo.bezerra
Hi
If I got this straight, you've setted a curtain which is rotated and applied to a face. Some parts of this face you want to be perpendicular (and/or parallel to the ground level.
I noticed that you removed the pin from the selected grid line. I'm not shure that's the best way to do it. I would suggest you divide the faces, and apply another curtain system configured to be paralllel to ground level.
Hope it helps
Regards
Rodrigo Bezerra
