Rotating just a view
76jsa
76jsa
how to rotate a view of a floorplan?
i dont wanna rotate whole project, just wann have lines orthogonally.
thanks
Highlight the view extents, use the rotate tool.
On a sheet view, select the view, in the view properties go to rotation on sheet
Cheers
cbcarch
Try using Project North and True North, set Floor Plan View to Project North.
--or, you can rotate a View on the Sheet.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
...I'd add to @Anonymous solution for clarity: Crop View Boundary is what you rotate
...suggestion: Duplicate View as INDEPENDENT first and then Rotate that duplicated view to work in.
Karol_Piroska
or you can rotate view by scope box.
