Rotating a view
Rotating a view
jacques
Message 1 of 22
Rotating a view
jacques
Does anyone know of a view to rotate an RCP say... 15 degrees instead of 90 degrees?
Replies (21)
Message 2 of 22
Draw a scope box, rotate it, and assign it to the view.
Message 3 of 22
jacques
I thought "scope boxes" only works with floor plans?
Message 4 of 22
chrisplyler
That's not correct.
Message 5 of 22
jacques
Ok, that was cryptic. Care to elaborate?
Message 6 of 22
Your assumption regarding scope boxes applications is incorrect. Try it with RCP and see.
Message 7 of 22
Perhaps I'm missing something with the question. You can rotate any plan or RCP by simply selecting the Crop Region of the view, use the rotate tool, and type in any angle. Keep in mind, you are rotating the view and not the elements, so you need to rotate the opposite direction of what you think.
Using a scope box works too, but seems like extra steps to me.
Message 8 of 22
@Anonymous
You are correct.  If a view is set to Project North then you can rotate its scope region directly and save a step.
But if it set to True North, then you have to change it to Project North first before you rotate the scope region, at which point you may have to recalculate the rotation delta again.  Or you can just assign it to a rotated scope box and be done.
Message 9 of 22
jacques
Tried that starting from a floor plan, then converted to RCP. Yet it made no difference. The RCP looked no different than the floor plan. The other choice would have been to change the project north. And that would have created problems for the other RCPs. At the end, we gave up and used a smaller scale.
Message 10 of 22
You cannot convert one View type to another, i.e. Floor plan to RCP, section to elevation, etc. Rotating Project North is obviously the wrong approach because it affects the entire project, not just one or some views. You could certainly rotate any RCP views the same as with Floor Plans. Perhaps that view had been associated with a scope box already and it prevented you from rotating it.
Message 11 of 22
Rotate RCP view:
Message 12 of 22
jacques
See, in our models, the option to associate a view with a scope box is "greyed out" for all RCPs. That is why we could not get it to work. We can do floor alright.
@ToanDN wrote:
Rotate RCP view:
Message 13 of 22
Are RCPs using a view template?  Are they True North?
Message 14 of 22
jacques
No template, true north,
Message 15 of 22
You cannot rotate true north views. Must change them to project north first.
Message 16 of 22
RobDraw
That is not a solution. It's not even a workaround. It's giving up. I hope you try to do it the right way as described @ToanDN after you marked this as the solution.
Rob
Message 17 of 22
jacques
Project north or true north, it didn't work. Scope boxes just don't work with RCPs.
Message 18 of 22
I would ask you to delete all sensitive data and share the file but you would probably say no.
Message 19 of 22
jacques
It would take a while to clean up the file. But, we can post it.
Message 20 of 22
Go to a 3d view and delete all model. Delete all Sheets and all views except for the RCPs.
